installing double din ? dash cutters help
Old Feb 20, 2007 | 03:31 PM
s2kspa02's Avatar
Banned
Default installing double din ? dash cutters help
i have the jdm bezel, and i have read threw and seen all the installs. iIknow it is custom using the bezel and cutting the dash. But how or what is being used to brace the headunit to the dash for the double din?
Old Feb 20, 2007 | 03:35 PM
NFRs2000NYC's Avatar
Im almost certain that the JDM bezel isnt compatible with double din HUs. I dont think that its big enough. I could be mistaken, but I dont think so. Also, the JDM unit is angled, and I dont think that will make it easy for mounting.
Old Feb 21, 2007 | 12:32 PM
s4play's Avatar
It won't work - it's not as easy as it seems - the JDM bezel is only for a LCD screen ONLY! At least not without cutting and modifying it......
rick
Old Feb 21, 2007 | 02:21 PM
s2kspa02's Avatar
Banned
i am doing the same eclispe doule din at the shop that you have in yours s4 play// with nav and satil radio.. awesome piece.. sure it will fit find since like you first said everything is custom.
Old Feb 22, 2007 | 05:53 AM
darkknight1999's Avatar
The fitment on the JDM bezels is less then perfect. You have to customize that piece just to make it fit right and then you have to fill in the 1/4 inch gaps your going to have along the edges... then in the end its tilled toward the passenger a bit.
Not to mention that I don't think a regular DD HU will fit into the bezel so your have to cut the up just to try and make it fit.
Old Feb 22, 2007 | 01:30 PM
s2kspa02's Avatar
Banned
i have read threw the post and talk to a friend he runs a audio shop in time and one of the best in the business when it comes to audio. i dont thing it will be that bad.. heres a link to his shop if you want to check out his work.. http://www.eliteaudioonline.com/
what i was really looking out is how you were building and attaching brackets to the inside of the dash.
Old Feb 22, 2007 | 01:32 PM
s2kspa02's Avatar
Banned
i ment town opps.. and check out press room
http://www.eliteaudioonline.com/index.php?...=display&ceid=7
Old Feb 22, 2007 | 01:36 PM
s2kspa02's Avatar
Banned
http://eliteaudioonline.com/index.php?modu...display&ceid=16
just a few more cars he build among the many.. what i;m doing is nothing compared to this stuff
Old Feb 23, 2007 | 10:13 AM
preilly44's Avatar
Anybody know of a good dash cutter in NJ, PA or MD? I'd like to go with a double din as well.
R00567
Feb 20, 2012 08:11 AM
boiii4
Jun 1, 2010 08:09 PM
E-autosports
Dec 6, 2007 11:59 AM
FMINUS
Dec 24, 2006 09:36 PM
Richee
May 10, 2006 01:34 AM
