keyless remote distance?
Originally Posted by xviper,Aug 1 2005, 05:37 PM
Next suggestion:
Stick it in your pocket, take a Viagra, wait about 1/2 hour, open your fly, point your XXXX and try it. It might not open your car door, but you'll feel randy for the rest of the day.
Or, you can try a new battery.
Go out to a lot, determine when the remote stops working, take a few steps more away and then try it.
As funny as the "under the chin" or "to your throat" methods appear, there's a reason they often work (and sometimes don't).
If you were to press the buttons on your remote using a 10' pole (why not, there must be a lot of 10' poles sitting around since no one will touch "this" or "that" with a 10' pole)... anyway, if you were to do that, the range on your remote would be quite low (on average). The reason is tied to how the remote is manufactured.
Human bodies have a nasty habit of detuning antennas. Engineers know this, so they design the antenna already out of tune... when you bring your hand near it, it brings the antenna back into tune. There's a surprisingly large rage of tuning the antenna can go through, so if one antenna is particularly out of tune, adding more body mass near it (such as holding it to your head) will bring it back into play and give you greater range. If the remote is already optimally tuned, you'll actually decrease the range by holding it to your head.
Not to mention look like a dumbass in public
Didn't I write about this in an earlier thread?
Before the antenna got relocated under the seat from the Alarm, I had exactly the same reception, TERRIBLE!
Plus I tested it with all 4 remotes, the 2 originals and 2 from the alarm and they were all the same, so it is very unlikely to be a battery issue, since all of the batteries could not be bad in brand new remotes...
So maybe it is a MY difference, seems the '05 has something obstructing the range...
SH
SH
