Knee Panel Removal
Old May 25, 2007 | 04:58 PM
bat711's Avatar
Default Knee Panel Removal
I'd like to remove the passenger knee panel (the dimpled plastic piece) to assist in wiring up a new head unit. I see a screw in the panel and I've undone that, but I'm assuming there are some more clips located somewhere before I can remove it. I've been searching for a while but can't come up with anything that points them out. Any help?
Old May 25, 2007 | 05:14 PM
AlabamaS2000fan's Avatar
Once you remove the screw, gently pry the piece loose. There are two clips will release when you pull.
Old May 25, 2007 | 05:22 PM
bat711's Avatar
Well I didn't manage to release the clips (or break them) but I was able to pry it up enoughto wiggle some cabling through...
Old May 25, 2007 | 06:47 PM
Saki GT's Avatar
it has two tabs that slide into holes - once you remove the screw, you just pull it back to get the panel off. fyi.
Old May 25, 2007 | 10:28 PM
bat711's Avatar
Thanks...I might revisit it at some point if I hardwire my sirius or upgrade my iPod.
altered7
Dec 11, 2015 06:45 PM
Canadia
Sep 5, 2008 03:59 PM
