LED Flasher in Third Break Light
Old Apr 26, 2017 | 07:48 AM
liyan1430's Avatar
Default LED Flasher in Third Break Light
Hi guys, I am thinking about to put a Flasher module on the third break light. So that way when I break, it will flash a couple times, which just like some euro cars.
I am thinking about to extend the connector? which the module will stay between wire harness and third break light. However, I have hard time to find another male and female connector to connect on both ends.
Just wondering is there other ways to do it? Or I have "cut" the wire harness and connect the module to it?
Anything would help,
Thanks
This is the module that I got:
12V 2A Flash Strobe Controller Module Flasher LED Brake Stop Light | eBay
Old Apr 26, 2017 | 08:23 AM
Ap2low's Avatar
I belive the pins can be pulled off of the connector to make installation a little easier. This seems like a good idea and should work great!
Old Apr 26, 2017 | 01:14 PM
licelsior's Avatar
That's the module I have, I have it hooked up to my rear fog light. If you look in the trunk on the driver side you'll see the wiring that leads to the 3rd brake light and that's where I tapped into.
Old Apr 26, 2017 | 01:46 PM
Chuck S's Avatar
Let us know, I'm interested. These are small cars an anything to make them more visible is nice.
Spell check won't save you (happens to us all!). It's a brake light.
-- Chuck
Old Apr 26, 2017 | 05:44 PM
liyan1430's Avatar
hmmm, I will give a try this weekend. Thanks for the suggestion.
And I am very interesting in those mudguards, they might be next
Old Apr 26, 2017 | 05:46 PM
liyan1430's Avatar
So basically wire it into the beginning of the harness?
Would you please send me a picture of what you did? Thanks
Old Apr 26, 2017 | 05:47 PM
liyan1430's Avatar
-- Chuck
Lol, I am so sorry about the wrong spelling, Thanks for correcting me !!!!
Old Apr 26, 2017 | 07:34 PM
JulieU's Avatar
Administrator
There is a company that makes a module. See www.pulseprotects.com. However, I'm not sure if you can DIY as it sounds like it might only be available through dealerships.
st3ven1
Aug 25, 2013 08:32 AM
Luke_sedz
Nov 13, 2011 11:45 PM
s2k.
Aug 13, 2009 12:43 AM
s2k_PikeStyle
Jun 21, 2006 09:53 AM
