LED Resistor Question
Old Apr 7, 2013 | 04:32 PM
Vee2k's Avatar
Default LED Resistor Question
Hey guys hopefully a quick question...
I am installing two 3mm leds in my door handles. The LEDs are 3mm rated 2VF @ 20mA. I made a mistake of buying 330 ohm resistors instead of 430 ohm. My question is can I solder two 330 resistors together to safely power the two LEDs? Did a few google searches and seems like I can but just wanted to run it by you guys to hear thoughts and opinions
Old Apr 7, 2013 | 06:11 PM
dustin02rsx's Avatar
Yes if you put 2 - 330 ohm resistors in series, you will have 660 ohms.
That will give you 15mA through your LEDs.
Solve by
(V_source - v_led) / resistance = current
(12-2)/660 = .01515
=15mA
The 330ohm by itself would give you 30mA
Edit I just saw you want to install 2 LEDs in each door.
(12-4) / 330 = 24mA
(12-4) / 660 = 12.1mA
Old Apr 7, 2013 | 09:07 PM
Vee2k's Avatar
Awesome thank you! Good thing I decided to solder while waiting for responses!
ek5686
Jun 27, 2005 12:49 PM
VTECnDaRed1
Apr 4, 2005 04:37 AM
DonTTgo
Sep 15, 2004 03:13 PM
chrts
Apr 24, 2002 07:47 PM
