Light for the ashtray
Old Nov 13, 2005 | 06:47 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Default Light for the ashtray
Installed an ashtray,in the cupholder,(OEM),but it's dark as hell,at night.
Would need to install a small size light,that would go on,when I turn on the headlights.
Should not be to big,or too bright.
Any ideas???
Old Nov 13, 2005 | 07:56 PM
xviper's Avatar
Quit smoking!
I understand. I smoked for 10 years once upon a time.
You have many options, but this would be my choice. First, you can use this power tap that will turn on the light when you turn on the car's light switch.
https://www.s2ki.com/forums/index.php?showt...0&#entry6487686
Run power from this to a couple of LED bulbs (pick whatever color you think will do the job) that you can attach them to the underside of the cupholder lid. You can attach it using black duct tape that you cut neatly. Run the wires down into the center console and out near your right knee, then over to the fuse panel. There should be enough slack in the wires so that the lid can open and close unimpeded. The LEDs can be wired in parallel. If you don't like the lid as a mounting place, you can choose some other handy location in that area where they will illuminate the ash tray.
Old Nov 13, 2005 | 09:23 PM
darkknight1999's Avatar
You can use an LED holder like this one:
I use them in my door handles.
Old Nov 14, 2005 | 09:17 PM
Incubus's Avatar
The Radio Shack in the Baton Rouge "Mall of Louisiana" had tons of those in the bargain bin. Pretty neat and easy to use.
Old Nov 15, 2005 | 07:03 AM
xviper's Avatar
He lives in Quebec, Canada. I doubt he's going to Baton Rouge to pick up a couple 2 buck LEDs.
Old Nov 15, 2005 | 09:21 AM
Incubus's Avatar
Oh, I thought it was Quebec, Louisiana... I'm just trying to get a post in there from time to time.
Old Nov 15, 2005 | 05:57 PM
Do you have a Quebec,in Lousiana???
I'll check Radio shack.
Thanks.
Old Nov 15, 2005 | 06:18 PM
Incubus's Avatar
No, No Quebec here. I was joking, as I'll bet XViper was too.
scai103
Nov 26, 2012 04:11 PM
brianlesays
Feb 27, 2012 07:54 AM
S2FARSI
Jul 20, 2010 06:38 AM
SjSharkS2000
Oct 10, 2007 04:00 PM
JasonX82
Jan 1, 2004 08:32 AM
