My first attempt at building a system.
Old Jul 24, 2004 | 11:57 AM
Cathan's Avatar
Default My first attempt at building a system.
Hi.
I
Old Jul 24, 2004 | 06:40 PM
Icemn2003's Avatar
I can speak for the Alphasonik PSW608 as I just put mine in last weekend, and I LOVE it. For an 8in, its really strong. It fills out the sound very nicely, I like alt. too, and it is a vast improvement over no sub. You can here it well even with the top down going 70 on the highway, and feel it thump, but its crisp and accurate and not overbearing.
I see you're planning on using a JL 250/1, I'd recommend sending it 300W, I'm currently sending mine 320 W bridged from a PG Tantrum, and the amp still tends to get pretty hot after driving for relatively short trips.
I can't speak for any of the other components, but I think I'm one of the few who has the PSW608, and I absolutely love it.
Rear speakers do help fill the sound, but I don't have mine amped (I thought about it) but I'm very happy with them now, they complement my amp Infinity Perfects well. Good luck!
Old Jul 24, 2004 | 07:37 PM
Chadwick's Avatar
Just remember that the tool kit also sits in the well, so when you mount everything you set it up so that it can be removed, and stored in the passenger seat safely if you get a flat.
The tool well is for storing the flat tire, so make sure you don't have a subwoofer in there either, or have a good plan of action especially if you have a passenger. Re: Auto club membership w/ towing.
Old Jul 24, 2004 | 08:49 PM
Cathan's Avatar
Tools I'll put in a towel in the spare. AAA member in case I get a flat, and can't change the tire for a short trip home. Good suggestion though.
Old Jul 24, 2004 | 08:51 PM
Cathan's Avatar
So at what wattage do I need to go to so that I don't run hot? 500? Any danger of over amping the sub then?
Old Jul 24, 2004 | 09:24 PM
NFRs2000NYC's Avatar
Quick note.....
The 600 series is a good sub (alphasonik), but the 800 is WELL worth the upgrade.
Also, To run cool, a 700wrms amp would be great pushing 450.
Old Jul 25, 2004 | 08:21 AM
Av8ing1's Avatar
I just put Focal 165A (Access) components in the doors and a JL 8W3v2-D2 in a Wlaurnet enclosure in my 04. I'm using a four channel amp with the rear channels bridged to drive the sub (2 ohm voice coils in series.) It sounds very good and the components are more bright than warm giving good definition to the vocals even at freeway speeds. The sub isn't going to rattle the trunk to death but definitely gives a tight satisfying thump to the system. I don't see any need to add speakers behind the seats, as the sound stage seems just about right with only the fronts. The 8W3 JL sub has modest power handling abilities, which was good for me as my amp only does 140W bridged. The Focals, particularly the higher line models, could use more power than I'm giving them. So in the future I might get a more powerful amp. Anyway, its nice given the space available, to run a single 4 channel amp. So if you run an 4 channel amp that can use up the power handling of the Focals, you could also run a sub with a higher power range than the JL 8W3. Also, I was going to leave the spare but changed my mind during my install. The spare well offers a lot of room and removing the spare helps offset some of the weight gain from the additional audio equipment.
JeffA
Old Jul 25, 2004 | 09:51 AM
Cathan's Avatar
Jeff - What amp are you using right?
I thought about getting a four channle amp and bridging a pair for the sub, but don't know enough about it to figure out what amp to get.
Would something like this Audiobahn work?
Old Jul 25, 2004 | 11:11 AM
Contrary to what many will say, that is a very very nice amp.
They are a tad heavy though. Their performance however, is fantastic.
Old Jul 25, 2004 | 12:11 PM
Icemn2003's Avatar
I think he's looking for an 8 in a Wlaurent enclosure, does alphasonik make an 8in in the 800 series?
