My install
Old Mar 21, 2009 | 10:10 AM
Sobe_Death's Avatar
Default My install
So I picked up a set of Phoenix Gold RSd 6.5" components for pretty cheap and wanted to install them. Well... I found out the hard way that the stock speaker baskets aren't a big enough diameter to fit a true 6.5" speaker so I had to wait. In the meantime I went ahead and deadened/sealed my doors.
Starting off, remove the door panel(obviously) and vapor barrier. Liberally apply sound deadening.
I didn't put as much on the outside skin as some have, but did double up behind the speaker.
For this to make a difference, we have to seal that huge hole in the door. I decided that I wanted a removable panel there so I wouldn't have to screw with cutting out and replacing deadening should I have to get in there. I used Aluminum flashing cut to shape with lots of deadener applied.
FINALLY, I got the speaker rings made so I removed the OEM tweeters
replaced with
Now the issue is that the OEM tweeters have a thread in the magnet to hold them to the little metal bracket. The Phoenix Golds, do not. I figured out that the OEM grilles would not interfere with the operation of the new tweeters and keep them locked in place very nicely, but it required cutting down the two plastic posts which previously held the tweeter bracket.
Original spacing with new tweeter
After cutting the posts. Perfect! As a side bonus, I think that the aiming this provides works very well for these tweeters(well, the best for the OEM mounting points.)
My custom CNC cut rings from Elemental Designs. I drew these up so that I could use the stock mounting holes. They still need a tweak or two(to the drawing) but I would highly recommend these to anyone. I will have to let ED know about my changes.
Keystone Man approves
Perfect Fit
Mounting the crossovers in the usual spot.
With everything buttoned back up, you can't even tell there is an aftermarket stereo installed. The real magic comes when you crank it and there is BASS coming from the front speakers. The OEM's liked the deadened doors but these are far superior already; I can't wait to hear them with the amp hooked up!
-Parker
Old Mar 21, 2009 | 01:55 PM
Neutered Sputniks's Avatar
Looking pretty good for a start.
Although, I wouldn't call that "liberal" amounts of sound deadening:
From my recent truck install (note that the inside of the door is just as well coated):
And inside the door skin:
Old Mar 21, 2009 | 03:09 PM
JumpDriver's Avatar
.........sigh
anyways......whats with the socks?
whats the dept on the RSd?
Looks like I'll know where to put sound damp. material now thx sobe.
Old Mar 21, 2009 | 03:55 PM
Sobe_Death's Avatar
Lol I thought you would chime in on the "liberal" application. I might need more when I upgrade to ID oem's, but for now this does plenty well. Plus, I did the deadening in the cold so I was ready to come back in! I also found that the OEM bracket bushings (the yellow ones) are much better at decoupling these mounting rings/speaker from the door than I would have thought.
JumpDriver- the RSd mounting depth is 73mm. With these 3/4" spacers it looks like there is about an inch clearance between the magnet and the little spool on the window.
Oh, and they aren't socks, they are my driving shoes!!
sanjay
Apr 7, 2010 07:29 PM
cjw07
48
Jun 19, 2009 07:00 PM
DeViL
Oct 31, 2005 09:45 AM
alks2k
May 24, 2005 06:08 AM
chardo
Aug 15, 2002 03:30 PM
