MY04 Radio Faceplate Removal
Old Nov 17, 2004 | 09:26 PM
vonHultgren's Avatar
Default MY04 Radio Faceplate Removal
I've seen this link...
http://lucidauto.com/Merchant2/merchant.mv...ode=radioremove
However I have a question...I tried to take my faceplate off tonight and for the life of me I thought I was going to break something. The bottom came off fine, but I can't get the vent seperated. HELP?
Can anyone provide some tips or success stories on how to get this plate off.
I feel like an idiot..but don't want to break it also....thanks for the help.
Old Nov 18, 2004 | 08:25 AM
jedraz's Avatar
I had the same problem. I used a pic which has s screwdrived type handle, and a L type bend at the end. I placed the L shaped end thru the heater ducts and pulled out. Not only will this not leave marks, but it also allows you to pull from the top sides.
http://www.sears.com/sr/javasr/product.do?...pid=00941513000
Old Nov 18, 2004 | 08:00 PM
timg's Avatar
Make sure you remove your center console first- it only takes a minute and makes it 100x easier to remove and install the radio cover. I've bent the lower tabs on my cover from not removing the center console.
Tim
Old Nov 19, 2004 | 04:43 AM
KaCee's Avatar
I use a paint can opener slid inside the vent so you pull from the backside....no scratches that way....go to home depot and ask for a freebee at the paint counter. It is basically a small tool with a flat hook on the end.
PichyRivera
Aug 10, 2011 07:04 AM
JDMSAMAD
Apr 7, 2008 07:05 PM
Duncs
Feb 8, 2008 10:28 PM
SLstone s2k kid
Jan 19, 2007 01:00 PM
puffycloud9
Apr 3, 2005 01:54 PM
