Mystery feedback buzz
Old 02-28-2018, 03:46 PM
2006kj's Avatar
Default Mystery feedback buzz
I have a 2004 Honda S2000 39k miles. It is bone stock except a tenabe medallion touring exhaust, berk high flow cat, and aem v2 intake.
When the radio/cd/aux is on i have a buzzing feedback coming through the passenger side speakers (both large bottom speaker and top tweeter). I tried swapping the speakers with the drivers side and the feedback continued through the passenger side door (with the drivers side speakers in it). So it is not the speakers. When the headunit is on volume ‘1’ there is no music just feedback buzz. It does change pitch with the engine rpm but very small amount. When you put the headunit on ‘mute’ or turn it from ‘1’ to ‘0’ the feedback buzz goes away. With the headunit off there is no feedback buzz.
My question is if replacing the headunit would eliminate the feedback buzz or is it just a frequency the speakers are picking up maybe from the engine or exhaust? Is there a ground for the passenger side door somewhere that could be bad?
Thank you so much for all the help. I’m fine changing the headunit if it’s the failed or failing part but dont want to waste money if changing the headunit wont fix the issue.
Old 02-28-2018, 03:53 PM
windhund116's Avatar
Received 1,451 Likes on 973 Posts
So with ACC on, but engine off, you get no buzzing through the speakers?
Old 02-28-2018, 03:58 PM
2006kj's Avatar
That's correct. Only when engine is running I get the feedback/buzz
Old 02-28-2018, 05:44 PM
2006kj's Avatar
I'm going to test the altinator and battery. If those check out I'm going to try to ground the battery to the chassis in a second spot . I'm still
guessing the headunit is on it's way out
Ghregy
46
01-04-2013 02:19 PM
europa
12-20-2008 11:24 AM
cullywoo
02-28-2007 12:17 PM
STEVE0163
09-29-2004 07:40 AM
Whaler
12-23-2002 02:06 AM
Quick Reply: Mystery feedback buzz
