Need DVD help pronto....
Old Apr 7, 2004 | 12:17 AM
NFRs2000NYC's Avatar
Default Need DVD help pronto....
Whats up junkies.......
Well I have decided against that Tablet DVD player, as I found out the resolution is crap. Anyway Ive decided to go with a cheap DVD player and a 300,000+pixel 7" monitor.
I need to know approx. what can I fit under the DRIVER seat....
Usually these players range from 6 inches wide, 8 inches deep (not an issue) and about 1.8-2.5 inches tall. (issue!)
Someone help a brotha out.
Thanks a lot guys!
Old Apr 7, 2004 | 01:59 AM
1a-race's Avatar
Banned
kenwood z910 dvd.
Old Apr 7, 2004 | 05:29 AM
PJK3's Avatar
hrm... Dave --
what's the dimensions of your CD changer?
i know Andy Kirk got your model changer mounted under the driver's seat by bolting it to the seat itself... (or was it under the passenger seat?? either way, if it fits under the passenger seat, it should fit under the driver's.) still, i'm fairly sure your changer is larger than the DVD numbers you listed above...
does that help? also, another way to do this -- buy some cheap closed cell foam from a hobby shop. trim to the dimensions of your DVD player, then test fit things... should cost less than $5.
Old Apr 7, 2004 | 07:49 AM
mikes2k's Avatar
I have the Alpine DHA-S680 6 disc DVD changer mounted under my seat it is Chassis Size (in) : 10" x 3 " x 8"
Old Apr 7, 2004 | 07:54 AM
1a-race's Avatar
Banned
why go through all the trouble to put one under your seat when you can just replace your headunit?
Old Apr 7, 2004 | 08:05 AM
PJK3's Avatar
sounds about right...
Old Apr 7, 2004 | 08:13 AM
mikes2k's Avatar
CORRECTION Its mounted to my seat...not the floor
Old Apr 7, 2004 | 09:55 AM
Does that make a difference in fitment?
Im not changing the headunit, cause I got a cheapo blaupunkt DVD player for like 105 bucks.
Old Apr 7, 2004 | 10:18 AM
mikes2k's Avatar
I am not sure (maybe) I will crawl under there when I get a break and see if I can tell
Old Apr 7, 2004 | 10:38 AM
Mike dont worry.......I found my Goodlife cologne box, which is 11 inches long, 3 inches tall, and 7 inches wide. It fits perfectly, only about an inch sticks out if you put it lengthwise.
I got this bad boy for my entertainment needs.
Under the seat it goes!
Not im stuck looking for a nice 7" monitor with 300+thousand pixels,for under 200 bucks. I found 2, a Pyle one and a Farenheight, but they wont fit my mount. Any ideas?
