need help amp overheated!
Old Apr 14, 2003 | 03:55 PM
whiteGoKart39's Avatar
Default need help amp overheated!
guys,
im running focal utopia 165w speakers + Audiobahn 2800E amp (200 per channel) + 02 Factory hu.
i usually listen to my music w/ xxtra bass and loud, but today my amp won't let me do that, It goes overheated everytime i turn up the volume or bass (or songs w/ heavy bass).
the cooling fan is working fine, the trunk is empty for my amp to breath. the xover control on the amp is ALWAYS at "full". HPF frequency is at "750 Hz". Bass boost is "off". when i try to turn the xover to "HPF" instead of "full" it will work fine but i don't get any more bass!! what happened to my amp? please help me all you audio genius.
Old Apr 14, 2003 | 05:06 PM
PJK3's Avatar
[QUOTE]Originally posted by whiteGoKart39
[B]
Old Apr 14, 2003 | 06:00 PM
Alister's Avatar
[QUOTE]Originally posted by PJK3
[B]ok, so normally it's set at full, but your crossover setting is 750hz?
Old Apr 14, 2003 | 06:05 PM
MacGyver's Avatar
You turned the high-pass filter to ON, and it surprises you that your bass disappeared?! What am I missing here?
Old Apr 14, 2003 | 06:33 PM
matrix's Avatar
When your amp cuts out, is it hot to the touch?
You want to keep the xover set to full.
Old Apr 14, 2003 | 07:11 PM
ricosuave's Avatar
all of your fuses intact?
Old Apr 14, 2003 | 07:56 PM
PJK3's Avatar
[QUOTE]Originally posted by MacGyver
[B]You turned the high-pass filter to ON, and it surprises you that your bass disappeared?!
Old Apr 14, 2003 | 08:03 PM
[B]
what resistance load do you have setup for your speakers?
Old Apr 14, 2003 | 09:39 PM
here is some pics of the amp setting/mount. (sorry about the quality, not easy to take pic at the night time)
i have no problem listening to my music w/ high volume, bass up this setting(pic) before today.
now when i turn the volume or bass up at this setting, my amp goes overheat.
Old Apr 14, 2003 | 09:43 PM
above,
GAIN CONTROL is at a little pass min
LPF FREQ is at 120 Hz
HPF FREQ is at 750 Hz
BASS BOOST is at off
X-0VER is at full
