Need help removing dash shelf
Old Nov 23, 2007 | 04:52 PM
s2k_redhead's Avatar
Thumbs down Need help removing dash shelf
Help!! I'm trying to remove the passenger side dash shelf in my MY'07 and can't figure it out. I found one center philips head screw but can't find the side clips to release it. I've already broken off the heads of what I thought were clips on the inside of the shelf and don't want to do any more damage. A Helms manual is on my Christmas list, but Santa hasn't brought it yet.
I'm trying to troubleshoot Modifry's DCI and need to get into the speed sensor wire...
Anyone who can help? Please???
Old Nov 23, 2007 | 05:58 PM
NVMY4N's Avatar
oh - there is a DIY some where - Ill post it if I find it......we did this at a Mod Day
Old Nov 23, 2007 | 06:03 PM
NVMY4N's Avatar
Im going to move this to the Electronics forum - Im sure they'll have a faster response.
can't find the DIY it's not where I thought it was....sorry
Old Nov 24, 2007 | 12:46 AM
stopmenot2002's Avatar
Let me start off a few pictures under that dash I did to mine monrhs ago. Hope this help
this is an 05'
this is the plug with the speed wire pulled
Use a tiny flat head screw driver, I go from inside the plug try to pick the plastic lock against the terminal then pulled the wire on the other side at the same time.
this is where th plug pulled off the module hanging loose below
Modifry module with grey wire run to the speed sensor wire
Below is my Ipod control unit module place on top of convertible top module due to not having much room behind radio (Yellow, black, white wires)
Good luck any more question you can PM me, I'm gald to help.
An
Old Nov 24, 2007 | 06:59 AM
this is an 05'
Hi An, thanks for the photos - this is the step where I need help, except that on the '06 and later, it's a new storage shelf. I can't find the clips or attachment points to get the shelf out.
Old Nov 24, 2007 | 09:21 AM
NVMY4N's Avatar
I think there is a screw on the Left Side....too
It's been a while - Ill PM a couple PPL the link to here to try and get you some more traffic. I thought the EJ's would hop on this pretty quick.
Old Nov 24, 2007 | 10:04 AM
Thanks - probably a lot of people offline during Thanksgiving weekend ...
Old Nov 24, 2007 | 10:31 AM
NVMY4N's Avatar
Okay
1 screw in middle of pocket
2 clips like in trunk liner where you have to press the center to get them to release - near the inside of the pocket - they go side ways
then you have to pop 6 clips like on an AP1 but they are prone to breaking.
Helms Manual over the phone FTW
Old Nov 24, 2007 | 10:59 AM
Great, thanks. I'll give it another go. I tried prying those side clips and broke them. I'll try pushing in on them with a screwdriver and see if I can get them to let go. I really appreciate your help!
Old Nov 24, 2007 | 11:08 AM
Bingo - that did the job. I just needed to get a pair of small needlenose pliers to get those little push-clips out, then I gave it a good tug and it came right out. Thank you!!
