Need Help running wires!
Old Oct 10, 2004 | 07:29 PM
nMeOnE's Avatar
Default Need Help running wires!
Ok i'm about to get ready for my install... Finally! i built a custom enclosure for my 10w3v2 sub in the back and gonna stick my JL 450/4 in the space next the spare tire.. Now i need help running the wires to my stock HU from the amp.. and power cables for the amp also to the battery.. Suggestions anyone? Pictures would also help alot.. Also which wire should i tape into the HU for the remote on for the amp?
Also i got a 4 channel line level converter and managed to tap the two rear channel in the stock HU so i'm getting 4 channel total for my amp .. now i just need help running it..
thx for your time and opinion
Old Oct 11, 2004 | 04:30 PM
r_duff's Avatar
check sticky at top of thread... there are LOTS of pics of installs there. I ran wires from my alpine to the amp in the trunk through the center console (pops right out). Remove the plastic panel behind the passenger seat. (removing the seat alltogether makes it easier) You can run wires through without having to remove the secret compartment. I ran the power line under the passenger side sill (from battery to amp) You're supposed to keep the signal (speaker) lines and power lines separated, to avoid line noise.
Red89gt
Sep 1, 2011 07:41 AM
TCLAP2
Jun 16, 2008 05:41 AM
ankuse
Aug 11, 2003 07:08 PM
NFRs2000NYC
Jun 30, 2003 11:03 AM
deadpedal
Jan 18, 2001 08:24 AM
