need some help from the experts
Old Jan 1, 2008 | 05:25 PM
s.hasan546's Avatar
Default need some help from the experts
Hey guys i just started working at circuit city and i got a crazy discount on kicker and eclipse products. (70% or more).
Im geting the Eclipse CD5100 headunit.
Im also geting 6.5" Kicker RS series front speakers. Im doing 0 AWG power wiring and 12 AWG speaker wiring.
I was wondering wut size speakers are our rear oem speakers?
Also what amp that kicker makes should i get to support the 2 front speakers? Is the zx2002 or zx2502 good?
If i get both rear and fronts what amp should i get?
And im not geting a sub...
How does all this sound? will the sound be significantly clearer and louder than stock?
Old Jan 1, 2008 | 05:56 PM
topnotchAp2's Avatar
The s2k doesn't have rear speakers.
Old Jan 1, 2008 | 08:04 PM
ryanfeldman's Avatar
no rears. 6.5 in the front as you stated and i like 5.5 in the back. if you go 6.5 in the back, it will be a tight fit.
Old Jan 1, 2008 | 09:15 PM
s.hasan546's Avatar
um i have the 07...
oops i meant um headrest speakers
Old Jan 1, 2008 | 09:30 PM
Stealth_SUX_'s Avatar
12 gauge is subwoofer wire, i hope ur not using that for speaker wire.. I would go with 16 gauge and nothing bigger..
And why would u run 0 gauge.. are u running like 1500 rms..
Not to be mean but do u know what RMS is...
Also if u work at circuit city couldn't u ask them for ur info...
I hope they didn't recommend that, but i would believe it coming from circuit.
Old Jan 1, 2008 | 09:41 PM
s.hasan546's Avatar
no its jsut that for power wire i get 0 awg for the same price as 4 awg and 8 awg.
Also i wasn't recommended it to me by CC but i was told that if i get all the wires for the same price i might as well get the best one ryte?
so i thought id do 0 awg for power wire b.c it wont cost me nething extra.
and yes i do know what rms is.... the Kicker speakers im geting r 100 watts rms.... so im prob going to get the zx2502 to power it
so would 0 AWG power wire hurt my car? is it better to have it if it wont cost me nething?
Old Jan 2, 2008 | 03:48 AM
daktruckie99's Avatar
Yea you are costing yourself about 20-30 pounds in extra wire and making it harder to run the wire cleanly.
No reason to overdue it even if you can.
Old Jan 2, 2008 | 10:34 AM
05S2KinClovis_CA's Avatar
0 Gauge in the S2K is not a good idea...even if the $$$ are the same for you. The wire is much heavier and thicker and will be difficult to run and hide in the car...FYI there won't be an extra 30 pounds with the thicker 0 gauge wire....that's just over exaggerating. I would still recommend the 4 gauge though...I'm running 1200 watts RMS and the 4 gauge is fine.
12 gauge speaker wire is over kill also for the doors. You'll get it to fit if you only run 1 set through the stock wire boot and mount your crossover in the door panel. If you are expecting to run 2 pair and mount crossover somewhere else you will have a Hell of a time getting them through the stock wire boot. 16 gauge is plenty.
You do realize you are only going to get 85 watts RMS per channel into your front speakers. Kicker...as most others rates their amps at 2 ohms. Your Kicker speakers are 4 ohm.
You might want to consider the ZX200.4. Run it bridged stereo and you'll get 100 watts RMS into 4 ohms...better match for your speakers. The amp is also shorter in length. 10 1/4 vs 13 1/2 for the ZX250.2. That will make a difference if you choose to add a sub and another amp later on....
Oh yeah...don't bother with the rears....no improvement and just run your new head unit to power them. No use amping them or replacing them.
Old Jan 2, 2008 | 12:23 PM
exacly what i was thinking guys ^
Old Jan 2, 2008 | 12:29 PM
s.hasan546's Avatar
wow thx guys for the help.. very appreciated!
Now i just wish i could get JVC headunits for cheaper and then i would buy NX5000 for my headunit
mattrh615
Jun 21, 2011 02:53 PM
AZDavid
Nov 29, 2009 10:39 AM
ProV1
Jan 6, 2005 07:54 PM
VTEC Racer
Apr 10, 2003 02:59 AM
Barry in Wyoming
Aug 15, 2001 07:16 AM
