New System but i have NO Bass!
Just talked to manager at Al & Eds. He insisted that even though it appears from what the manual says that the crossovers for the tweeter and mid-range on the Polk components don't block the low frequencies, they actually do. He really didn't believe me when i said that according to the manual there isn't any block of the low frequencies.
But he offered to have a look at it tomorrow, even so.
Could he be right?
Could he be right?
Originally posted by Gantra
Could he be right?
Could he be right?
Ask Lucid about this, he sells these speakers. You can also do a search for "EX3560" on the electronics and see who else has them and ask them about it.
if that was true, it's simple to test, just bypass the xover and go directly to the speakers.
but i've never heard of component speakers doing that automatically, usually there is a switch on the xovers to set that.
like mas said, those speakers were made to play bass.
There seems to be some misunderstanding about the function of crossovers. Crossovers divide up the audio frequencies such that the high frequency drivers (tweeters, midrange) get the high frequencies and the bass drivers get the low frequencies via a low pass filter (removes the high frequencies). Do not connect tweeters directly to the speaker cables without the crossover (which in its simplest form is just a capacitor) since the tweeter could get fried by too much power. If you wanted to know if the crossover is misdirecting low frequencies to the tweeter instead of the bass driver, you have probably already done that by turning up the power and not frying the tweeter. Your only simple test is to see what comes out of the bass drivers. Turn the treble off with the HU controls. If there is absolutely no bass, even with the balance control turned to get sound out of either the right or left side alone, then (provided the amp has no high-pass filter) it's your signal source. If the bass sounds better with one speaker only, it could be a phase problem. Just reversing the lead connections of one of the bass drivers would fix this. If your amp has an option for passing only highs or lows to an amplifier section, then that may be the culprit. But, why are you doing all this head-scratching. You paid someone to install it. They should be responsible to fix it for you.
Originally posted by mas
I know the focal tweeters get quite bright if you set the attenuation to 0db at the crossover. Most people are using the -4db setting and I even have a series resister on top of that. The Polk crossover does not seem to have any option to attenuate the tweeter? If the polk tweeter it's anything like the focal at 0db, that'd definitely overpower the bass.
if we don't have some sort of clear resolution on this by Friday afternoon, i'll drive out by Circuit City and see if they have a set on the wall that can be listened to... that would definitely give me an idea of how bright and/or bassy these components are... problem is, it'll take me 10 minutes to convince the sales guy that i don't want the treble and bass maxed out and the loudness on...
PJK3 just to clarify, the text you quote in the manual is for those installing subs and WANTING to block low frequencies from their mid-range speakers. That's a different story.
But there IS actually a low frequency cutoff in the crossovers. It blocks low frequencies from being directed to the tweeters.
My point about the crossovers is that the terminals going to the tweeters are high-pass (no low), and IF the woofers were connected to the wrong terminals you might get Gantra's symptoms. Coupled with the fact that his tweeters are making his ears bleed, that's why I was suggesting he double/triple check on the connections.
When hooked up correctly, of course, low frequencies are not blocked to the woofers.
Now, I have never hooked up speakers wrong in this way. In theory you could blow the tweeters rather easily, but that will only happen at a certain power level. Main point was to check the connections.
Originally posted by mgiang7
AMEN, i think the Alpine "MX" mode sounds terrible!
[QUOTE]Originally posted by LATEOTT
[B]PJK3 just to clarify, the text you quote in the manual is for those installing subs and WANTING to block low frequencies from their mid-range speakers.
