No need for rear speakers
Old Dec 18, 2002 | 09:55 AM
  #21
PWRMKR's Avatar
[QUOTE]Originally posted by offroadr35
The one thing i'm slightly disapointed in is how hard it is to actually get bass into the cabin.
Old Dec 18, 2002 | 12:42 PM
  #22
offroadr35's Avatar
Originally posted by PWRMKR
Am I reading this wrong or what?
how are you reading it wrong? i'm referring to the sub amp.
Old Dec 18, 2002 | 08:10 PM
  #23
supwithyou's Avatar
I have indeed tested the use of rear speakers in my vehicle and they are indeed necessary. I am running a high powered Alpine amplifier on 6.5" Infinity Components in the doors, and 5.25" components in the rear.
With just the fronts hooked up the volume had to be turned up much higher to get the same sound volume with 4 speakers. So by having to turn the volume up higher you are making the front speakers work harder which could cause them to blow faster, and they are not as clear. So we hooked up the rear components, and not only did it add a bit more highs, but the volume was increased, and the overall output is incredible.
The amp and head unit have been fine tuned and the sound can be turned up to just as high as youd like without any distortion. I utilized factory speaker locations(the rears should be factory), and did not hack the vehicle. The infinity components fit right into the holes without any cutting etc.
So in conlusion, go with front and rear speakers just like almost every vehicle in production comes with. Head units have front and rear channels for a reason!
Old Dec 18, 2002 | 10:34 PM
  #24
r2d2's Avatar
No wonder when you have your speakers blocked by your legs (!!!). Try to use either my setup with subs in the doors or high end 3 components system like Shanner is using (Dynaudio) and you will see (hear) you get plenty of sound and soooo clear...
Old Dec 19, 2002 | 05:39 PM
  #25
HondaGuy347's Avatar
[B]
actually i don't have the amp bridged right now.
Old Dec 24, 2002 | 10:19 AM
  #26
spapdx's Avatar
Car sounds better with rears than without rears. End of story.
Old Dec 27, 2002 | 09:52 AM
  #27
shaner's Avatar
Not trying to be too diplomatic here, but our personal senses are quite unique to the individual... Good sound, taste, color, etc is entirely dependant on the individual, their chemistry and their unique neuron firing-patterns. Sure you can measure frequency curves, S/N, etc but what a person calls "desirable" or "pleasant" is completely up to that person and how their biology works.
BUT before you knock something, you've got to try it... so try the rear speaker install before you say it's not necessary or "unpleasant"... I tried it first before declaring it uneeded and a distraction from my stellar front stage.
People, you've got to get along!!! Respect each other!!!
Last thing: It's my dash. If I want to cut holes in it, it's my dash!
Old Dec 27, 2002 | 11:16 AM
  #28
xpander4's Avatar
Originally posted by Mindcore
Common concensus is that rear speakers have a HUGE improvement in any system.
I have to disagree. I have 100watts per channel going to my MB Q-series components, and I see NO room for improvement in the mids/highs ranges. The way to go in this car is DEFINITELY to shell out some bucks for a quality component set with a nice crossover, rather than shelling out those same bucks for rears.
Old Dec 29, 2002 | 09:12 AM
  #29
Hondafan's Avatar
[QUOTE]Originally posted by xpander4
[B]
I have to disagree.
LudeAtic
Jul 14, 2006 09:40 AM
Saki GT
Jun 20, 2005 12:46 PM
Icemn2003
Jun 6, 2003 03:22 PM
jss2k
May 13, 2002 01:48 PM
Ross
Dec 7, 2001 01:28 AM
