OEM Alarm -> Honks too loud
Old May 21, 2007 | 07:34 AM
eniety's Avatar
Default OEM Alarm -> Honks too loud
I am assuming the OEM alarm is installed in my 2002. The first time I hit the lock button on the fob it locks/engages and HONKS. Although I'm constantly worried, I don't lock it if I come home late at night, because I don't want to be inconsiderate to the neighbors (apartment). One lady jumped and gave me a dirty look in a parking lot the other day when I came back to my car and unlocked it. I've also tried to lock it using the door locks, but that also engages the alarm.
I used to own another 2002, but it didn't have the OEM alarm. I would hit lock once on the fob and it would lock silently. I could then hit lock a second time, if desired, to let out a honk.
Is there a way to silence or quiet down the horn when engaging/disengaging the alarm?
Old May 26, 2007 | 12:21 PM
Spectre48's Avatar
You can make it not beep at all and be silent. Just press the option and the lock button at the same time for 2 seconds.
Old May 26, 2007 | 05:58 PM
broilmebk's Avatar
^^^ that'll do
the honk is pretty dam loud.
everytime i unlock/lock at a parking lot people nearby always look
i like the looking tho
Old May 27, 2007 | 12:11 AM
iKMTi's Avatar
Banned
wat option button?
ok, i got an 07
I have unlock, lock, trunk, and Panic.
So what do I need to press to make it do silent lock and unlock?
Old May 27, 2007 | 03:35 AM
Dave-ROR's Avatar
iKMTi: you just have the normal keyless entry, not the OEM alarm right? If so, it's silent unless you push it twice.
Old May 27, 2007 | 04:10 PM
broilmebk's Avatar
i'm not sure about the 07, but on my 02 the option button is the trunk button.
i hold the 'trunk' button and the lock button at the same time for 3 seconds
Old May 29, 2007 | 10:30 AM
shamoo's Avatar
Originally Posted by iKMTi,May 27 2007, 01:11 AM
wat option button?
ok, i got an 07
You have the same one as I do, it's the standard keyless entry remote. If you press the lock button once, it will flash the lights and lock it WITHOUT honking the horn.
If you press lock again within 5 seconds or so, it WILL honk the horn.
Just keep an eye for the flashing parking lights to know that it was locked successfully and you're good to go.
Old May 29, 2007 | 11:11 AM
GPWhiteS2kFTW's Avatar
onces locks silently,
twice honks
you might have a bad trigger finger, lay off the Counter Strike
Old May 29, 2007 | 11:15 AM
webmasterino's Avatar
Stick a sock in it?
I say that tongue in cheek but...
Old May 29, 2007 | 12:04 PM
iKMTi's Avatar
Banned
I got an AutoPage Alarm system
Press once - LOCK with SOUND
Press TWICE - Panic Mode
I try the option button = trunk + lock... does not work.
So I guess I can't do any silent lock.
