OEM Alarm wiring
Old Jun 6, 2008 | 04:29 PM
spyhunter's Avatar
Default OEM Alarm wiring
Hello, I've read threads stating that there is a pulsing negative signal for the AP2 dash light when the alarm system is armed, but I need a constant 12V or constant ground to give power to some extra lights that I want to use as a deterrant.
I've looked through some threads with alarm wire descriptions, but it doesn't look like there's anything constant that I can use?
Thanks for your help!
SH
Old Nov 1, 2008 | 10:34 AM
spyhunter's Avatar
Well, I'm still looking for an answer to this question, is there really no such wire?
SH
Old Nov 1, 2008 | 12:45 PM
Cubs2k's Avatar
Originally Posted by spyhunter,Jun 6 2008, 07:29 PM
...... but I need a constant 12V or constant ground to give power to some extra lights that I want to use as a deterrant.
Constant Ground?
How about any point on the chassis......
as far as 12V Constant....there are 3 spade terminals on the fuse block....
https://www.s2ki.com/forums/index.php?showt...0&#entry9174841
sadly this pic seem to be gone, however, the three terminals are 12V Constant, 12V Switched/Ignition and 12V Lights.
30 Seconds with a multi testor will tell you which is which. You can also tap off the battery though for your 12 V Constant.
Old Nov 7, 2008 | 10:02 PM
spyhunter's Avatar
No, I'm talking about 12V positive ONLY WHEN the alarm system is ARMED, in order to activate some deterrant lights.
SH
yorkies2k
Nov 22, 2014 01:34 PM
team510
Jan 14, 2012 10:24 AM
S2Kmonkee
Apr 29, 2010 12:09 AM
B.Money
Jun 3, 2007 10:16 AM
autoconcept
Jan 14, 2001 10:03 AM
