OT: Looking for Switched Power in 1999 Odyssey
I got cocky after it was so easy to install the hard wire kit for a radar detector in my S2000, I volunteered to do one for my wife's 1999 Odyssey. However, I can't find switched power for it. I've found unswitched power, but no switched power. Can someone point me to such a wire I can tap into? Or a socket, like the S has?
Thanks.
Thanks.
WIRING INFORMATION - HONDA / ODYSSEY / 1999
12volts white + ignition harness
Starter black/white + ignition harness
Second Starter
Ignition black/yellow + ignition harness
Second Ignition yellow + ignition harness
Third Ignition
Accessory white/black + ignition harness
Second Accessory
Keysense
Power Lock black/white - green 6-pin plug
Notes: The plug is located at the bottom of the fuse box.
Power Unlock green/red - green 6-pin plug
Lock Motor white/red green 10-pin plug
Unlock Motor lt. green/red green 10-pin plug
Parking Lights+ red/black 10-pin plug
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal
Second Starter
Third Ignition
Second Accessory
Keysense
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal
mongomery1234
Apr 13, 2014 02:02 PM
DongTran
Mar 9, 2004 10:30 PM
