Passenger door speaker problem..
Old Feb 1, 2006 | 01:27 AM
AP1_fanatic's Avatar
Default Passenger door speaker problem..
Hello
The passenger door stock speaker would be working fine for 20 minutes, and then it would stop while driving. The next day.. the speaker wouldn't be working, but then 10 minutes into the drive.. it would start working fine. And this has been happening for the last few weeks.
So I've had it with listening to one speaker. BTW, I have a MY2000. I'm planning to take apart the door panel and see for myself if I can do anything.
Am I correct in assuming the speaker is not blown since it still works fine?
Is this problem common? If so is there anybody that can lead me into finding a fix for this.
Thanks everyone.
Old Feb 1, 2006 | 03:50 AM
hukares's Avatar
I'd suspect the wire is shorting or has a bad / corroded connection.
Old Feb 1, 2006 | 04:45 AM
darkknight1999's Avatar
Sounds like the connector is loose.
Old Feb 1, 2006 | 05:40 AM
NFRs2000NYC's Avatar
Thats not correct. Its actually, "Sounds like A connector is loose.
Old Feb 1, 2006 | 08:06 AM
modifry's Avatar
Honorary Member
You guys don't remember this?
MY2000 had a problem with the radios where the audio would just cut out. it was a problem with the HU itself. Honda did warranty replacements but I don't know if there was a technical bulletin on it or not.
So if that's your problem chances are you'll have to get a new HU. If yuo decide it's a bad HU you can probably find one cheap.
Bandolero
Mar 29, 2014 07:30 AM
DownSouthWS6
Feb 13, 2014 06:43 AM
rikhemi
Sep 13, 2009 07:20 AM
nightzone
Aug 18, 2008 04:32 PM
GrittyShaker
Dec 12, 2007 06:37 AM
