passenger side speaker doesnt work
Old Mar 18, 2005 | 10:50 AM
gots2000's Avatar
Default passenger side speaker doesnt work
Just wondering what would cause this? Is it just my speaker is blown or what?
Old Mar 18, 2005 | 11:54 AM
Bass's Avatar
could be...
aftermarket speakers??
could be a lose wire
amps??
factory head unit??
could be a bad channel
you get the idea
what's in your car and i'm sure someone can help narrow down your problem
Old Mar 18, 2005 | 01:50 PM
gots2000's Avatar
stopped working after i had my alarm installed. I just have an after market stereo in it also
mas's Avatar
mas
If it's a stock system, it's probably a bad wire/connector in the door. Since your tweeter works, the wiring from the HU to the door should be fine.
You need to open up the door and have a look. If you need instructions, look here:
http://users.myacc.net/~macgyver/Mic...dio/audio.html
Good luck!
Old Mar 18, 2005 | 01:57 PM
mas's Avatar
mas
What exactly?
* Is is just aftermarket head unit?
* Do you have aftermarket speakers? If yes, where are the crossovers, in the door?
* Any amps?
Help us help you.....
Old Mar 18, 2005 | 04:20 PM
Willie Gee's Avatar
i don't think the alarm should be installed anywhere near your speaker... the guy that installed it pulled a wire loose somewhere.
No sound at all? this is important. if it is getting a weak signal it is a totally different problem.
No sound?
Remove the mid bass driver to see if the wire is disconnected on the back of the speaker itself. I think that this could easily be the culprit. With no sound at all the speaker wire is disconnected somewhere...
stock speakers or aftermarket?
Old Jul 9, 2006 | 08:09 PM
dawheat's Avatar
Does anyone have instructions to opening the passenger door to check the speakers? I'm having the same problem with my passenger side speaker - no sound comes out at all. The tweater is very very faint even at max volume.
Completly stock system (04) - any help would be greatly appreciated.
Old Jul 10, 2006 | 12:40 PM
oth's Avatar
oth
go to:
http://lucidauto.com/
and click on "S2000 Audio Installation Guides"
Old Jul 10, 2006 | 01:17 PM
NFRs2000NYC's Avatar
Please go to the FAQ on the top of the electronics section for instructions and pictures on how to take the door panel off.
If your tweeter is working, means the problem is NOT with the amp connection or the headunit connection. It is one of 2 things (assuming the woofer isnt blown)...
1)One wire fell off/came loose on the woofer.
2)One wire fell off/came loose on the crossover.
Old Jul 10, 2006 | 05:29 PM
Dave-ROR's Avatar
Your problem may be differnet from the OPs (his case sounds like a bad wire connection, or maybe a bad xover). First obvious thing for your case, what's the balance set to on the radio? If that's fine, try another speaker (you'll have to figure out a way to connect wires to the stock harness to another speaker to test that though). If could be a bad channel in your case.
sharksfinn
Nov 20, 2015 07:36 AM
3Pedals_6Speeds
Oct 7, 2013 08:28 AM
Gulf Island S2000
May 11, 2008 10:31 AM
benswuk
Mar 11, 2007 12:32 PM
