Passenger side window won't work
Old Jun 13, 2015 | 06:39 AM
ML Clayton's Avatar
Default Passenger side window won't work
Hi there, I saw one person posted on this topic last year but didn't post a solution. So I'll try here.
Pass side window got stuck about halfway open - couldn't move it with passenger or driver switch. But when I put the top down, the window came down just like normal, and now is stuck there. No funny noises so it doesn't seem like a mechanical issue. I am guessing the issue should be either the pass side switch, or the control unit switch on the drivers side, but haven't tested either yet.
As a side note, my battery just went dead while sitting in the garage, it was 8 years old so it was time. Replacing today. Coincidence? Or could be short-related somewhere?
Is it possible to pull off the door panel without special tools? Or should I get the special door trim part from Honda?
Anyone have any thoughts on this one? Thank you in advance for your help.
Old Jun 13, 2015 | 07:27 AM
oth's Avatar
oth
It's easy to remove the door panels without special tools. No doubt the web is
full of instructions - here's one set.
Before you open things up though, make sure the passenger window lockout switch
on the driver's side isn't the cause if you haven't already.
Old Jun 13, 2015 | 12:03 PM
ML Clayton's Avatar
Thanks! Yep it was the power window lock that and a new battery and everything's good as new!
RHIT_S2000
Jun 2, 2016 10:27 AM
FIRSTCAR-S2K
Mar 8, 2016 03:05 PM
Currahee474
Nov 5, 2006 01:22 PM
dhayner
Jul 8, 2004 08:44 AM
ayelien
May 22, 2004 09:17 PM
