Power Window Activation Problems
Old May 22, 2004 | 06:12 AM
ayelien's Avatar
Default Power Window Activation Problems
Can someone help
I just replaced my passenger door with a whole new door. The window is currently in the down position. I am 95% sure the power window regulator is good and everthing looks as it should. The main electrical is hooked up to the drivers side door and the passenger side door and I am trying to ooperate both windows from the drivers side switch. I do not have the inner door pannel or switch connected on the passenger door. The drivers side window goes up and down fine but the passenger side window will not budge. When I hit the drivers side control button for the passenger window down it will click so I think it is getting power but when I hit the switch top go up I hear or get nothing. Can anybody offer some advice?? banghead:
Old May 22, 2004 | 09:57 AM
MacGyver's Avatar
Check the child lock switch on the driver's door...
Old May 22, 2004 | 10:32 AM
ayelien's Avatar
Did that already. When on I get no click when I try to lower. When off I get a click when I try to lower but nothing when I try to raise.
Old May 22, 2004 | 10:45 AM
MacGyver's Avatar
I just noticed...you don't have the passenger door panel connected. I believe that needs to be connected before the driver's side will control it.
Old May 22, 2004 | 02:00 PM
ayelien's Avatar
Ok
I'll check it out
Old May 22, 2004 | 08:13 PM
Slows2k's Avatar
MacGyver is correct, both window switches need to be plugged in for the passengers window to work.
Old May 22, 2004 | 09:17 PM
ayelien's Avatar
Figures it would be somethig that simple,
RHIT_S2000
Jun 2, 2016 10:27 AM
connieholmes
Jun 22, 2013 12:53 PM
BrianTucson
Aug 27, 2008 03:12 PM
ghoward11
Jun 2, 2005 12:41 PM
dhayner
Jul 8, 2004 08:44 AM
