Placement of subwoofer remote?
The Infinity BassLink sub I just got came with a wired remote, does anyone know of a good place to put this thing? Here is a pic of what it looks like :
I already hit my knee on the radio door when its open, wouldn't that just make things worse, or do you mean lower down still from there? Any other placement suggestions?
I say take that whole thing apart. The box is hugh compared to the actual circuit board. You can take the whole thing apart and put it almost anywhere. Its not something you'll mess with every 2 seconds but you will mess with it a little. It might just fit next to the HU, in such a way so just the knob sticks out of the HU bezel, so when the door is closed you can't see it and when you open the door its right there. Might take a little work with a Dremel it shouldn't be that big a deal.
I have one for a memphis amp, looks about the same. I took it apart, unsoldered the switch from the board and then soldered the wires of cable directly to the switch tabs. This way I can mount it anywhere by drilling a hole and using a bulkhead nut to hold the switch in. haven't mounted it yet, but it works. There are no othercomponents on the board to worry about.
Originally Posted by tk_chatt,Jun 10 2005, 02:47 AM
How do you like the BassLink?.... I considered that when I started putting mine together....
Is there enough drive to get the sound out of the trunk when you're at speed ?
- Clarion ProAudio DXZ945MP head unit
- Clarion DCZ625 Changer (to be mounted under the driver seat)
- Polk Audio MOMO Carbon C300.2 amp
- Polk Audio MOMO Carbon MMC6500 separates
- Infinity BassLink sub
Oh, and if I measured right I'm looking to do a "big 3" wire upgrade using 1/0 as well.
