Power window not working
AP2/2007, right side window not working.
Tried both switches.
Tried to replace fuse.
When i try to lower window with switch I hear "click" from under dashboard on passenger side but window won't move and i don't hear motor running either.
Motor works both up and down (with removed panel, when wired directly to battery) - window slides freely to both stops no issues.
Please help: what can it be?
Yes, if i switch it off, i can no longer hear a "click" when i try to operate passenger window, so it seems this part is working.
Looks like the window switch sends +12v to the convertible top control unit (under the passenger-side dash), which in turn operates the
passenger window, unlike the driver's window. The top control unit appears to be a different fuse, so it may be that fuse which is a problem,
especially if you haven't tried the top. Looks like fuses 17 & 18 are the relevant ones.
Which fuses are you referring?
I tried to swap these - didn't help:
yes, those are the two that the electrical manual shows for the power windows and convertible top control unit.
At this point my best guess would be a broken wire where it enters the door, but that's total conjecture. The connector
for the door harness is a 16-cavity gray connector behind the right kick panel if you want to have a go with a multimeter.
Window motor test:
There's a 2-pin connector inside the passenger door. The window goes up or down based on polarity at this connection. 12v+ to one contact and 12v- to the other. Swap them and the window will go the opposite direction. Looking at the terminal (pin) side of this male connection pin 1 is on the left; pin 2 on the right. {+ -} should move the window up. { - +} should move it down. Disconnect immediately when the motor stops running. If nothing happens the motor is bad.
You can also check the connection into the door with a volt meter the same way. Polarity will change depending on pressing Up or Down on the switch.
Page 22-235 of the 2007 Service Manual. Page 22-129 of the on-line 2003 edition with the Japanese girl in the bikini on the cover that you can down load.
-- Chuck
-- Chuck
Window motor test:
-- Chuck
-- Chuck
After some fiddling around, window will go down, but not up (and no voltage on connector). I hear click from right side of dashboard when i push switch to lower window, but can't hear anything when i push to lift it. Switch is culprit?
