Probably a silly question...
Old Sep 22, 2006 | 05:56 AM
Scott2000's Avatar
Default Probably a silly question...
I'm having a little trouble getting my CD deck out. It really confounds me as I had no problem last time.
Anyway, I've got the trim piece pulled off and I'm to wear the screws are holding the deck in place. The bottom two screws came out no problem, but the top two screws spin and spin, but aren't seem to be caught in any threads, so they don't come out. However, I also can't pull out the deck at all. It won't budge even a bit.
Any ideas?
Old Sep 22, 2006 | 05:59 AM
Dave-ROR's Avatar
So the screws turn but don't actually back out?
Stripped clip/nut whatever they go into?
Maybe a really small flat heat (a bit probably) to put some force on the screws while turning them? By force I mean force in the direction they need to go - towards you.
Old Sep 22, 2006 | 06:01 AM
Scott2000's Avatar
Exactly, they turn, but don't back out. It just seemed strange that the bottom screws had no problem, but both of the top ones got stuck like this.
I'll give your suggestion a try. It's just tough because of the limited space you're forced to work in while in there. But thank you, I'll let you know how it works.
Old Sep 22, 2006 | 06:26 AM
Dave-ROR's Avatar
Actually instead of the small screwdriver, just try pulling on the HU (obviously not REAAALL hard) to put pressure on the screw. Depending on the type of fastener that it goes into (I can't remember what it was anymore) that will allow it to back out - at least enough until you can easily get something else under it to put pressure on it.
Hmm I was just looking at some of my old pics, on my car it looks like there's a metal fastener of some type behind it, either a nut or a clip. If it's a clip it probably just came off it's mount when you started turning, kind of like how a nut will turn when you turn a bolt. If that's the case this might be a PITA. I've never tried to access it from behind, put maybe if you remove the side triangle shaped panels you can visually inspect it?
Old Sep 22, 2006 | 06:32 AM
Scott2000's Avatar
Well, I finagled with it for awhile, then put the bottom two screws back in, and huzzah, the top ones caught on their threads and started to back out.
So I got all the screws out, and now I can't get the Kenwood SW1 to work. I'm freakin' hopeless when it comes to audio stuff.
Old Sep 22, 2006 | 07:55 AM
SuzukaS's Avatar
the same thing happened to me with one of the screws for the H/U, i think the clip things on the back for the screws suck bad or something.
Old Sep 22, 2006 | 12:56 PM
Scott2000's Avatar
That's exactly what the problem was. The little metal clips the screws go into are just a little bit too big if you try and take the screw straight out. It has to be at a very slight angle for the threads to catch.
I'm just glad I got all the stuff accomplished today that I wanted to.
CynicG
Jun 23, 2015 11:11 AM
CrashnBrn
Sep 15, 2010 06:17 AM
dsthez
Nov 30, 2009 08:28 AM
s2jay
Apr 10, 2008 03:15 AM
