Problem with E-manage blue
Hey, I just finished installing my turbo kit and I'm trying to get my car to run properly with the Emanage blue. I have 600cc injectors and have the old/new injectors entered into the parameters. Car idles fine, no CEL. When I take it for a drive with the data logging, the car runs lean if you try to accelerate, I still havnt taken the car over 3500 as to avoid engine damage. Using map trace in the addition injector map even when the parameter is 30% increase my total combined fuel % is only at about 14%??? and the largest increase in fuel from the addition injector map is only 6% when the first value I have is 10%
Anyone had this happen before? How do I go about correcting this? If more info is need please let me know so I can get this resolved.
Thanks in advance
John
Here is a screenshot...My intake manifold pressure is at 3.XX and rpm at 3XXX and still I only have a total injector duty of 12% when it should be adding at least 30% fuel?
Thanks in advance
John
