Quick Speaker Question
Old Mar 6, 2010 | 11:07 PM
MurderS2K's Avatar
Default Quick Speaker Question
So ive settled for a set of speakers for my fronts, the size is 6.5 with a top mount-depth of 2 3/8.
The FAQ here states - "The S2000's door speakers are 6.5" diameter speakers. What prevents installation is usually an issue of mounting depth. Using the data found on MacGyver's site (yes, the real MacGyver wink.gif) the rear depth of the space for speakers is 68 mm (2.68") on the top and 79 mm (3.11") on the bottom. "
This might be A REAL DUMB QUESTION. But this audio tech i spoke to at a local shop CONTINUALLY INSISTED i would need a spacer for these speakers to fit or else the window would hit them when lowered.
Isnt this set of speakers going to fit just fine? If i am wrong - what size spacer would i need?
Old Mar 7, 2010 | 02:28 PM
MurderS2K's Avatar
N e 1.....
Old Mar 8, 2010 | 06:35 AM
Reckon's Avatar
From what you posted, doesn't seem like it would be an issue.
What speakers did you get? You can always double check on Crutchfield to see if they will fit the S.
Old Mar 8, 2010 | 09:03 AM
MurderS2K's Avatar
one of 2 sets - the pioneer ts-d602p or the polk audi
Old Mar 8, 2010 | 12:13 PM
oth's Avatar
oth
since very few speakers will fit in an unmodified OEM speaker basket,
you're going to need a "spacer" of some sort. Could be the original
speaker basket with the back cut off, or perhaps a ring made out of MDF -
5/8" works well, and I believe 3/4" will fit if you need the depth.
Here's a link to the previously mentioned MacGyver's site which may help you.
Old Mar 8, 2010 | 01:31 PM
MurderS2K's Avatar
thank u, i was just wondering "wth is a speaker spacer and where or how do i get one"
Old Mar 8, 2010 | 05:08 PM
oth's Avatar
oth
while no doubt someone at some point has installed a spacer on top of
the original speaker basket, in general the spacers people refer to are
simply a ring that goes between the door and the speaker in place of
the stock basket, usually 5/8" or 3/4" thick.
here's another thread to check out...
S2000&1
Dec 5, 2013 07:21 AM
plutonium239
Aug 13, 2007 10:46 AM
Rusted_nailz
Jul 18, 2006 12:14 PM
TepEvan
Mar 26, 2003 07:28 PM
tenblade2001
Aug 15, 2002 08:32 AM
