Radio bracket "locate pins" blocking install
Old Jan 2, 2025 | 07:45 AM
car5m's Avatar
Default Radio bracket "locate pins" blocking install
I am trying to install a Sony DSX-GS80 headunit in my s2000 by reusing the brackets from the OEM headunit. Unfortunately, the brackets have two locate pins (see photo) that don't line up with the holes in the Sony headunit.
I suspect that there are a lot of possible ways of resolving the issue:
- Finding a compatible aftermarket bracket without locate pins
- Removing (cutting, sanding, etc) the offending locate pins, though this would require tools that I dont have
- Installing the new headunit without the bracket (the Sony headunit came with a flimsy-looking sleeve system)
- Drilling locate holes into the new headunit
- Returning the Sony headunit and purchasing a different model with the correct locate holes.
Any ideas as to what would be easiest?
Honda s2000 radio bracket
Honda s2000 radio bracket "locate pins"
Old Jan 2, 2025 | 08:10 AM
spider2k's Avatar
Active Streak: 30 Days
do yo have a file? file them off.
do you have a hammer? set the bracket on something solid and hammer the nubs flat.
Old Jan 2, 2025 | 09:37 AM
car5m's Avatar
Luckily, my neighbour has a bench clamp and Dremel, and was able to remove the pins in minutes. This is the easiest and cleanest way to do it.
If he hadn't helped, I would have tried using a file as suggested by spider2k above.
AP1_Silverstone
Oct 1, 2013 01:35 PM
ill mitch
Oct 9, 2006 07:37 AM
S2kNY
Jul 31, 2006 12:05 PM
Hondafan
Jun 3, 2002 07:25 PM
