Radio Fuse keep blowing out
Old Apr 8, 2009 | 10:46 AM
S2Kmonkee's Avatar
Default Radio Fuse keep blowing out
Just like the title , in the last week, i went through 3 fuses already. Fuse Number 9 for the radio to be exact. (10 amp) What's going on?
Old Apr 8, 2009 | 11:13 AM
DFWs2k's Avatar
too much power is being drawn through the fuse
have you checked your grounds and everything? maybe something is shorting out?
Old Apr 8, 2009 | 12:52 PM
oth's Avatar
oth
in addition to the radio, fuse #9 is the power outlet. do you have
something plugged into it?
if not, you likely have a loose wire somewhere which is shorting out.
Old Apr 9, 2009 | 04:59 PM
S2Kmonkee's Avatar
where should i be checking as it's all OEM?
Old Apr 9, 2009 | 05:34 PM
DFWs2k's Avatar
even your radio is OEM? i think 'oth' is asking if something is plugged into the lighter...
Old Apr 9, 2009 | 05:39 PM
S2Kmonkee's Avatar
yup even my radio is OEM. I have my phone charger plugged into the lighter.
Old Apr 9, 2009 | 06:09 PM
DFWs2k's Avatar
hmmm...maybe someone else will chime in now...i don't think that would be causing problems unless someone else had jacked with the grounds, or the connections could just be bad...
is there any correlation between using the lighter jack to charge your phone and the first fuse blowing? how about unplugging the charger and see if a fuse still blows?
Old Apr 10, 2009 | 10:06 PM
S2Kmonkee's Avatar
well it's been like 2 days since my fuse went out again so im good so far. I'm not very good with electric stuff so i left everything as is. I don't think the charger had anything to do with the fuse but so far everything is good so hopefully it was just a fluke >.< thanks for all the replies so far.
Lainey
May 19, 2016 06:34 AM
PokS2k
Jan 29, 2011 02:11 PM
chillout18
Jun 19, 2009 11:04 PM
F20Chris
Nov 27, 2005 01:53 PM
gbuka
Apr 27, 2005 10:45 AM
