RCA sub out on deck...do I need a y-cable?
Old Feb 17, 2009 | 07:09 PM
crazydude's Avatar
Thumbs up RCA sub out on deck...do I need a y-cable?
Here is my issue. My sony cdx-gt710 has 2 sub-out RCA cables. The deck install manual indicates that it is "MONO" as can be seen here...
http://www.xplodsony.com/files/manuals/CDX...tall_Manual.pdf
My amp says to take a single rca signal, split it up with a y-rca adapter and feed it into the L and R inputs on the amp. Page 50 indictaes the mono subwoofer in this manual for my amp model RAB250...
http://www.maxxsonics.net/manuals/mbquart/...erence_Amps.pdf
Which is the best way to do this??? Does the mono sub-out feature send EXACTLY the same signal to each rca output??? If so why have two then??? Will it be alright to use only 1 rca and use a y-adapter??? If the signal is different for each subout ... and I join the signal... that could cause some serious odd reactions from the sub as it could be getting 2 different signals for left and right from the deck at the same time for different sound notes!??!?! How would you hook this up?
here are the options I see infront of me...
1. Use y-adapter at cd deck... use 1 single rca cable to the amp...use y-adapter at the amp to split signal to the left and right amp inputs
2. Only use 1 output from the cd deck... use 1 rca cable to the amp... use y-adapter at the amp to split signal into both the L and R inputs
3. Use both RCA outputs... use 2 rca cables... feed directly into the amp into L and R input.
Anyone wanna give me some input? Thanks
Old Feb 17, 2009 | 07:31 PM
Neutered Sputniks's Avatar
Just run a regular pair of RCAs. Hook both up at both ends. No worries.
Old Feb 17, 2009 | 08:06 PM
crazydude's Avatar
So it is a pretty standard thing for dual rca sub out rca's even though it is mono?
Old Feb 17, 2009 | 11:50 PM
Claus's Avatar
your amp will sum up the signal, just run one pair like NS said The actual reason for this has to do with impedance, but I won't bore you with that
crazydude
Oct 5, 2008 04:01 PM
DFWs2k
Sep 14, 2007 01:35 PM
Drinks2k
Mar 19, 2007 04:35 PM
RadioSilence
Apr 7, 2005 06:08 AM
sunrise089
Feb 2, 2005 06:35 PM
