re-pin a stereo harness
Old Apr 17, 2007 | 09:21 PM
BowlofRice's Avatar
Default re-pin a stereo harness
Is there a special trick to doing this? I'm trying to move some pins so i don't have to splice into the honda harness for my dci. Or do you guys know where I can go to buy new pins? I already tried radio shack but to no avail.
Old Apr 18, 2007 | 07:24 AM
oth's Avatar
oth
The plastic connector has little ramp-like "ratchets" molded into it that
allow you to push the pin in and then it holds the pin in from the back.
You need to push the ratchet down to remove the pin. I was able to do
it with a tiny jeweler's screwdriver inserted through the hole below the
pin from the pin side, grabbing the end of the ratchet and pushing it
down while pulling on the wire. If you have something thin enough,
you should in theory also be able to do it from the wire side by simply
pushing it in between the pin and the ratchet, and then pulling out
the wire. Kind of hard to describe, I hope you get the idea.
Old Apr 18, 2007 | 05:11 PM
BowlofRice's Avatar
sweet thanks! the trick was doing it from the pin side instead of the wire side.
turbo8765
Nov 12, 2011 08:55 AM
Luder619
Jun 8, 2010 12:14 PM
01silverstones2k
Aug 22, 2007 06:25 PM
kev1025
May 19, 2005 09:16 PM
kev1025
May 7, 2005 04:55 PM
