Rear speaker problem
Old Mar 21, 2003 | 07:43 AM
Reignman's Avatar
Default Rear speaker problem
I purchased new speakers for my door and installed the stock speakers in the panels behind the seat and every time someone sits in the passanger side and puts pressure on the seat the speaker cuts in and out. I checked the wiring and it is securely attached to the speaker. Does anyone have any idea what could be causing this?
Thanks
Old Mar 21, 2003 | 08:14 AM
xviper's Avatar
Is one of your speaker wires touching or nearly touching one of the metal support braces? It could be shorting out when pushed. Try using some electrical tape to wrap each speaker connection. It could also be possible that your connection is not as solid as you may think it is.
Old Mar 21, 2003 | 04:29 PM
Reignman's Avatar
Thanks for the suggestion xviper. I will try that.
Old Mar 21, 2003 | 06:55 PM
matrix's Avatar
Do what xviper suggest quickly...a short to chassis ground can hurt your amplifier (even the internal one in the stock deck).
s2kkyo
Dec 9, 2007 12:36 PM
ignition25
May 11, 2007 10:10 PM
AZDavid
Mar 27, 2005 06:23 PM
Bassoctopus
Apr 7, 2004 03:09 PM
baldy74
Aug 9, 2002 01:48 PM
