Rear Speaker Question???
Old Jan 6, 2003 | 12:37 PM
b0mbrman's Avatar
Hmmm...I guess I'm convinced then.
Is it worth it to get the rear panels from Lucid?
Pilotchris: did you use a Dremel? Round cutting mystifies me for some reason
Old Jan 6, 2003 | 01:00 PM
xviper's Avatar
A dremel is one way to do it. I used a "jig saw" and it worked pretty good. However, if your jig saw blade moves too fast, you'll start to melt the plastic as the cut. You can avoid any melting if you have a helper trickle water at the cutting point. If you're not handy, then the Lucid panels are for you but I decided to do it myself. Remember, measure twice, cut once.
Old Jan 6, 2003 | 02:48 PM
PilotChris's Avatar
Yeah I did like xviper and used a jig saw and I also followed his rule of measure twice and cut once. If you take your time and make sure your speaker measurements are accurate you'll have no problem.
Old Jan 6, 2003 | 06:47 PM
Tedster's Avatar
I used a Dremel, and the "measure three times, cut twenty-seven times" method. In other words, cut the initial hole too small, and just keep enlarging it until it's right.
Old Jan 6, 2003 | 06:48 PM
b0mbrman's Avatar
Heh, That's the method I used to make my clock hole
Old Jan 6, 2003 | 10:29 PM
b0mbrman's Avatar
[QUOTE]Originally posted by PilotChris
[B]I know exactaly what you mean by the front speakers getting muffled by your legs... very annoying.
If you put in rear speakers, although they are physically muffled by the seat, the sound seems to travel upward and around both sides of the headrest.
WongGahming
Aug 5, 2003 09:18 PM
NavinRJohnson
May 2, 2003 09:40 AM
supwithyou
Aug 7, 2002 08:07 AM
pcovers
Sep 6, 2001 11:55 AM
honda_s2k
Aug 15, 2001 07:44 AM
