Rear speakers vs Biamping
Originally Posted by Orthonormal,Dec 6 2005, 11:42 AM
Definitely double check in the manual before bridging -- it can be really bad for the amp if you try to bridge channels that are already bridged!
It's also possible to bridge an amp that doesn't have bridging built in. An amp capable of bridging is nothing more than an amp with one input reverse polarity (swap + and -) and then the output is reversed too (net result zero). If you put an inverting op-amp circuit ahead of one channel of a non-bridge-able amp and then use the + output from each channel the result will be a bridged output. .
Of course you might fry the amp if it can't handle the current. Minor details.
You can also do this with two identical mono amps, as long as the amps are not already bridged of course
