Relay Question
Old Jul 26, 2004 | 11:13 AM
stocks2k's Avatar
Default Relay Question
I need help finding a relay that can work with a 24 volt system. I need the relay to be open with power to it and close when power is removed. When it is closed with no power I need it to send 24 volt power that is then stepped down to 12 volts. If anyone can help please let me know.
Thanks in advance.
Old Jul 26, 2004 | 11:23 AM
ruexp67's Avatar
Do you need to activate it with 24VDC, or just pass 24VDC?
Forgetting the activation for a second...
Your best bet would be to put your 24VDC source to it, then hook up your full voltage load to the NC side, then use a resistor and perhaps a diode on the NO side to step down the voltage. Or, if your amperage is very high, use the NO relay to fire a different relay that has a 12v source.
gaus
Nov 11, 2009 09:14 AM
Will
Jul 23, 2008 11:29 AM
whiteGoKart39
Aug 14, 2006 12:31 PM
enoyskt
Nov 7, 2004 09:16 PM
infinitebass
Mar 27, 2003 11:28 PM
