Question on converting 12V power supply!
Old Nov 5, 2004 | 04:56 PM
enoyskt's Avatar
Default Question on converting 12V power supply!
Hi, I had a question if you guys could help, I want to convert the cars 12V source to 5 or 6Vs to power a small DC motor. What size resistor should i use? (OHMS) Thanks
Old Nov 6, 2004 | 04:56 AM
MacGyver's Avatar
Need more info. The voltage level in your car will fluctuate from about 11.3V when off to up to 14.5V when running. Do you not care the specific voltage level that it is dropped to? What current level is required?
Old Nov 6, 2004 | 06:54 AM
burnmacs's Avatar
http://focus.ti.com/docs/prod/folders/print/ref02.html
That can give you 5V +/- 150mV at a price of $4.07 from Digi-Key assuming you don't need more than 1.4mA.
Mike
Old Nov 6, 2004 | 07:27 AM
MacGyver's Avatar
1.4mA is the supply current, not output current, for that piece. Also, it's not even close to being suited for a motor application. Unless it's a pager motor, the moment it turns on you'll swamp the regulator.
Let's wait until we understand the application before suggesting components...
Old Nov 6, 2004 | 07:53 AM
burnmacs's Avatar
Sorry 21mA, I didn't read the spec sheet and tried to qualify it being for lower power apps. At any rate, cut me some slack... I think the chemicals the water damage recovery crew sprayed after this morning's flood in my apartment are getting to my head
Old Nov 6, 2004 | 10:19 AM
enoyskt's Avatar
This is a small 12V DC motor that only goes 5000RPMs. It probably has 1 or 2 watts going through it, Imagine a Servo on a RC car or an RC car motor spinning real slow. The cars 12V power spins the motor at its highest speed 5000RPM, I tested a 6volt power source to it which made it spin slower and that is what I want. Im guessing there is only 1 or 2 watts going through it. Is this enough info? Some tech shop told me I should get a resistor but he didnt know how many OHMs to get
Old Nov 6, 2004 | 04:57 PM
MacGyver's Avatar
Use a multimeter and measure the resistance of the winding... that will tell us how much current it pulls at 12V. Once we know the current, we can suggest appropriate values. Resistors will be the (slightly) cheaper method, but a voltage regulator will offer a constant speed.
Old Nov 7, 2004 | 09:16 PM
enoyskt's Avatar
Ok, I got some ratings off the small 12V DC motor im using:
Gearhead Motor
60 RPM, 12VDC @ 110mA
This spins to fats when I plug it straight up to my cars 12V power supply. I want it to spin slower, I tried hooking it up to a 6V battery and it did spin incredibily slow, which is what I wanted. So how would I get this motor to spin to the speed of 4 or 5Vs?
stocks2k
Jul 26, 2004 11:23 AM
Marc one
Nov 11, 2003 12:48 PM
infinitebass
Mar 27, 2003 11:28 PM
tripod
Apr 9, 2001 11:25 PM
