Remote stop working
Old Aug 21, 2010 | 12:45 AM
Terry Kwok's Avatar
Default Remote stop working
I parked my car in the parking lot and find that my remote didn't work. So i through my battery go bad and i bought a new battery. The light is flash, but it won't be able to unlock the door. It is 00 S2000.
Any advance
Thanks
Old Aug 21, 2010 | 12:32 PM
emac0408's Avatar
You could try reprogramming the remote. It's a bit of a pain but worth a shot.
Storing transmitter codes: The codes of up to three transmitters can be programmed into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps. Make sure the doors, the hood and the trunk are closed.
Turn the ignition switch ON (II).
Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the receiver unit behind the driver's side dash.
Within 1 to 4 sec., turn the ignition switch OFF.
Within 1 to 4 sec., turn the ignition switch ON (II).
Within 4 sec., turn the ignition switch ON (II).
Confirm you can hear the sound of the door lock actuators. Within 1 to 4 sec., push the transmitter lock or unlock button again. The keyless receiver unit is now in the program mode. You must push the transmitter lock or unlock button of the first transmitter again to program that remote.
Within 10 sec., aim the transmitters (up to two additional ones) whose codes you want to store at the receiver unit, and press the transmitter lock or unlock buttons.Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
Turn the ignition switch OFF, and pull out the key.
Old Aug 21, 2010 | 07:17 PM
common reactor's Avatar
Anything but going to the stealership.
Old Aug 22, 2010 | 07:21 AM
S2000Matt's Avatar
I just bought my car and one of the remotes doesn't work even with a new battery and after programming it. The red light also doesn't flash. Am I right in assuming this remote is dead?
Also, these remotes aren't vehicle specific since you need to program them, right? A friend of mine knows someone at Honda and says he can probably get one because they have a bunch laying around. That should work, right?
Old Aug 23, 2010 | 03:48 PM
S2000Matt's Avatar
bump
Old Aug 27, 2010 | 11:22 PM
Terry Kwok's Avatar
I remove the battery and the remote work's fine now. However, I don't have radio code now.No music at all. It's killing me.
Thanks
mikey430
May 9, 2015 10:16 AM
lipice
Mar 18, 2014 03:51 AM
skiddy1903
Jan 26, 2008 04:57 AM
Grazhoppa
May 4, 2006 06:36 AM
B.C.
Jan 25, 2006 09:57 PM
