How to PROGRAM the S2000 Remote?
I got an extra remote that I want to program for our car. Is there a way, or must we head to the dealers?
Thanks for all the help. Step by step for this novice is great
BC
BC
I answered my own question...
Storing transmitter codes: The codes of up to three transmitters can be programmed into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps. Make sure the doors, the hood and the trunk are closed.
Turn the ignition switch ON (II).
Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the receiver unit behind the driver's side dash.
Within 1 to 4 sec., turn the ignition switch OFF.
Within 1 to 4 sec., turn the ignition switch ON (II).
Within 4 sec., turn the ignition switch ON (II).
Confirm you can hear the sound of the door lock actuators. Within 1 to 4 sec., push the transmitter lock or unlock button again. The keyless receiver unit is now in the program mode. You must push the transmitter lock or unlock button of the first transmitter again to program that remote.
Within 10 sec., aim the transmitters (up to two additional ones) whose codes you want to store at the receiver unit, and press the transmitter lock or unlock buttons.Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
Turn the ignition switch OFF, and pull out the key.
