Removing Dash Trim?
Old Sep 20, 2007 | 06:17 PM
GyozA's Avatar
Default Removing Dash Trim?
Like the title says I need help removing the dash trim so I can repaint it. I just need some instructions on how to remove it w/o screwing anything up. Any help is appreciated. Thanks in advance.
Old Oct 22, 2007 | 07:25 PM
satthu1982's Avatar
i would like to know also...anyone know how??
Old Oct 22, 2007 | 08:44 PM
Will's Avatar
Click here:
http://hondatech.info/downloads/Auto/Manuals/S2000/
then click on "Ab0VE Honda S2000 (00-03) Service Manual.zip" to get the service manual. Interior trim removal is in section 20-68.
Old Oct 22, 2007 | 09:27 PM
Stealth_SUX_'s Avatar
Originally Posted by Will,Oct 22 2007, 08:44 PM
Click here:
Yep, has a great explanation there... Basically you have to drop the steering column so you wont scratch up ur dash..
Old Oct 22, 2007 | 10:09 PM
2big4aS2000's Avatar
easy,
pop out to trim plugs inner pannel, remove 2 screws
remove 2 in back and 1 in front of bottom steering wheel trim panel, pull bottm panel off, remove top panel, loosen back 2 bolts 12mm of the steering column, now remove front two nuts on steering colum, this lets steering wheel drop down. now i use my fingers to pull the middle top loose and put my finger behind panel and work it around, reach behind and unplug all the plus - its off!
Fat
Sep 17, 2016 03:09 PM
Mar48
Jun 18, 2011 11:13 AM
j8mie
Oct 10, 2010 03:30 AM
s2k_Nut
Jun 28, 2008 06:59 AM
stewies2k
Jul 28, 2007 06:30 PM
