Replace stock door wiring?
Old Jul 30, 2002 | 06:15 PM
matrix's Avatar
Don't forget that the output side of the amplifier will be at a higher voltage rating, therefore, needing less current to produce the same amount of power.
Old Jul 30, 2002 | 07:40 PM
s2k330's Avatar
Thanks for all the input and info. I am planning on a speaker wire replacement in the near future.
Old Aug 1, 2002 | 11:29 AM
MacGyver's Avatar
Damn you, modifry, stop checking my numbers...that's at least TWICE now you've busted me Excellent analogy, BTW...
But I still stand by my statement about running the system at full power versus low power. At low power (your 50% value), he'll be fine, but would you really want to run any wire at the "smoking barrier" when cranking the volume? Not me!
Old Nov 19, 2002 | 09:08 AM
johnnydev's Avatar
Sorry to keep resurrecting old threads but...
If I give up on running new wire into the door (I'm running 12 ga. throughout) should I use as short a length as possible of the existing wire? Or doesn't it really matter?
Thanks,
jd
Old Nov 19, 2002 | 01:33 PM
MacGyver's Avatar
For these purposes, distance won't matter. You could chop off a foot or two in the distance, and you'll only be making a 0.5%-1% change in resistance, if that. 12 Guage should be adequate for most systems, but don't think that 12 Guage hooked up to 2' of 24 Guage is going to be anywhere near the power-handling capability of pure 12 Guage...it'll be the same power-handling capability as 2' of 24 Guage, and that's that.
Old Nov 19, 2002 | 02:44 PM
lucid's Avatar
12 gauge is kinda overkill for the doors, ideal for subs. Should be fine with 16 gauge. I like the Tsunami twisted double insulated easy to work with and durable
Old Nov 19, 2005 | 08:44 PM
PJK3's Avatar
ahhh... here's where this thread has been hiding.
personal keyword: evenflo
Old Nov 19, 2005 | 10:27 PM
Incubus's Avatar
I have a question...
Can I attach new wire to the old wire and pull it through the grommet, or do I need to just remove and reinstall separately?
Old Nov 20, 2005 | 06:41 AM
mas's Avatar
mas
From what I remember, the existing speaker wire is bundled in with other wires going to the door so forget about it. Run the new wire seperately and let the old wire be.
Old Nov 20, 2005 | 07:45 AM
darkknight1999's Avatar
^ you need to pull it in seperately. But its easy.
