Reverse lights don't work!
Old Aug 8, 2011 | 03:26 PM
unison21's Avatar
Default Reverse lights don't work!
I checked the fuse for the reverse lights that share the same fuse for the dome light according the S2000 manual. That is fine and my dome light works. I also checked to see if the bulbs worked and tried a different set and that wasn't it.
The weird thing is that my dome/map lights work only if I fiddle with it. But when it does work, my reverse lights still don't work.
Any ideas?
Old Aug 8, 2011 | 04:11 PM
gumbey75's Avatar
take a multi-meter and with the red lead put it to green/black found on the drivers kick on a 17 pin white plug and the black lead to ground. It should read 0 Volts and with it in reverse it should read 12+ Volts. if not then It's shorted somewhere or a different fuse is blown that shares the same circuit. Or sounds stupid but maybe both bulbs are out....
Old Aug 9, 2011 | 08:49 AM
2big4aS2000's Avatar
how about reverse switch unpluged or not working.......
Old Aug 10, 2011 | 10:54 AM
TPhong's Avatar
^ like he said. Have you had any transmission work done recently? If so, they may not have plugged the reverse switch back up or you may have a bad switch. See if this helps.
https://www.s2ki.com/s2000/topic/781...-light-switch/
bryant.cw
May 14, 2015 05:59 PM
wiley_s2k
May 11, 2012 02:13 AM
AP1SiiK
Feb 16, 2007 06:53 PM
VegaS2k
Sep 24, 2006 09:50 AM
Johnny--2K
May 5, 2004 01:29 AM
