Right headlight quit-turn signal and all!
Old Jan 7, 2020 | 04:58 PM
happ's Avatar
Default Right headlight quit-turn signal and all!
Like the title says, this morning when I pulled the car out of the garage after sitting a couple of months I turned the headlights on no problem. Then while driving out, I turned the defroster on and the right headlight shut off! It just flickers when I hit the switch. Then I tried my turn signals and the same right turn signal on the headlight doesn't work anymore either.
Checked the fuses and all is good. I'm gonna swap the relay next. I don't think it's a ballast since the turn signal quit too. Anyone ever had something like this? I'd really appreciate any help
Old Jan 8, 2020 | 04:26 AM
engifineer's Avatar
Have you looked at the wiring at the light itself? Is your inner fender liner intact on that side or has it been damaged at any point? First step is to ensure all wiring is good and not damaged before starting to swap out relays and parts
Old Jan 8, 2020 | 09:39 AM
happ's Avatar
Yea I did look at the wiring and didn't see anything out of place or damaged. The ground was tightly secured too. Inner liners are in place on both sides. This is looking through the engine bay though. I'll try swapping the relays around first since it's easy. Idk if there's any fuses under the dash that may control this too but I'll check. Then I'll go down the route of pulling the front bumper.
I was just hoping someone had something similar as having multiple things go out at once might trigger a specific part.
Thanks for the thoughts man
tklash
South Florida
17
Jan 5, 2023 06:10 AM
blink962
Mar 20, 2022 10:46 AM
Mdeck
Nov 1, 2017 07:29 AM
Crazyasianrice
Arizona Classifieds
Sep 2, 2017 01:56 PM
