Rockford Fosgate Amp Problem
Old Mar 28, 2007 | 11:20 AM
Maskdman3's Avatar
Default Rockford Fosgate Amp Problem
One of the channels is out in my old Rockford Fosgate 501x. I bought a used 551x from Ebay and am all ready to make the swap.
The screw that holds the end caps on appears to be a standard allen wrench socket (hex key). Apparently it is not. I have 2 complete sets of allen wrenches (1 standard and 1 metric). None of them will fit.
How do I remove this bolt? I have to get the end cap off on one end to access the wiring points. The other end is RCA so I can reach in and grab them without a problem.
I have tried several methods without any success. At this point, I am left with either drilling it out (which I really, really do not want to do) or welding an allen wrench to the socket and then unscrewing the newly formed single piece.
I am looking for suggestions. I really hope somebody has a better approach for this.
Old Mar 28, 2007 | 11:28 AM
darkknight1999's Avatar
Just go to a local hardware store tell them you need to buy a single allen wrench but your not sure what size so you need to try a few different ones. Most True Value/mom and pop hardware stores won't have a problem with it.
Old Mar 28, 2007 | 11:37 AM
Maskdman3's Avatar
Is it a readily available size? I have two complete sets of allen wrenches. One is standard and the other is metric. Neither set has one that fits.
Old Mar 28, 2007 | 11:42 AM
You might think you have a complete set but maybe your missing an inbetween size or something.
Old Mar 28, 2007 | 12:04 PM
DFWs2k's Avatar
Yea, rockford fosgate uses allen wrenches, they also suck, IMO.
Old Mar 28, 2007 | 12:18 PM
Maskdman3's Avatar
I'm a recent college grad which is code for "I'm broke." I had to put something back in there to actually have sound and this amp was dirt cheap.
I've been reading all of the DIYs and various project threads with my mouth watering waiting for the day when I can fund my own personal project.
Old Mar 28, 2007 | 12:20 PM
which is code for "I'm Broke" I have felt that pain and it hurts...
That's way if you go to the hardware store you can buy one allen for about $2 bucks
Old Mar 28, 2007 | 06:33 PM
PJK3's Avatar
actually -- bring the car/amp to the mom and pop shop, and let them find you the right wrench. then you can buy it.
might it be a torx screw? (star head?)
heck, they may even let you loosen it for free.
Old Mar 28, 2007 | 06:42 PM
DFWs2k's Avatar
lol, i purchased the 2 rockford fosgates that i used and blew within about a week of owning each while i was still in college!!
that's why i won't buy another one...but if it works for now...
Old Mar 28, 2007 | 06:47 PM
Maskdman3's Avatar
As usual Darkknight1999 was right. After going through several sets of allen wrenches I found one that fit.
I pulled the amp out and popped in the new one. The problem was still there. Grabbed the front and rear right side RCAs and plugged them into the front left and right inputs on the amp. I now have sound on both sides again.
Long story longer, my amp was fine. My head unit has lost a channel.
