Running cables through center console?
I know a number of you have mentioned running wires through the center console, my question is how hard is it to get them from there to in the trunk? I am trying to get a game plan together before I tackle the system install.
Originally Posted by imdarkrider,Feb 28 2008, 04:46 PM
easy if you go to the left or the right at the back... if you try to go straight back it's a bitch
Originally Posted by imdarkrider,Feb 29 2008, 01:23 AM
it's cake period.... you'll have to pull down the carpet behind the seats...
here's a visual of how I ran on someone's car , both power and RCA
Here are a few photos showing cables run through the center console.
Hardest part is running them down into the console by the SRS module.
I used a piece of solid copper wire to thread through, then taped the
cables to it and pulled them through. To get them out the rear, I
loosened the screws visible in the last picture, pushed them under the
rear console, and you can reach them from there after removing the vent
panel behind either seat.
4-channel and 2-channel RCAs, as well as twisted-pair speaker wires heading
into the center console:
around the handbrake:
under the rear console:
