S2000 AP2 cluster problem :(
Old Jul 18, 2009 | 06:13 PM
rsxer63's Avatar
Default S2000 AP2 cluster problem :(
We just installed a 2007 AP2 cluster in my RSX and we have a couple of problems ... hopefully someone can tell me what the wires are on the s2000 cluster that pertain to our problems or provide a wiring diagram for the 2007 cluster.
1: Oil pressure readout....
Do I just hookup a oil pressure sensor?
Where on the cluster does it get hooked up to?
2: Brake light won't go out
3: Outside temp...
Is anything other than the temp sensor needed... ie something to take the
temp sensor and convert it to a reading the cluster can use.
What pins does it get hooked up to on the cluster?
4: For some reason the door open indicator will not work for the drivers
door but it does work for the passengers side and hatch.
5: VSA ... how do you turn it off permanently?
We used black tape but I would like a better alternative.
tia,
Ron
Old Jul 19, 2009 | 03:10 AM
leo520's Avatar
why don't u use the 05 or pre model ap2 clusters into the RSX?
06+ are all DBW , so the pre models doesn't have the VSA lights.
Old Jul 19, 2009 | 07:45 AM
rsxer63's Avatar
[QUOTE=leo520,Jul 19 2009, 03:10 AM]why don't u use the 05 or pre model ap2 clusters into the RSX?
Old Jul 20, 2009 | 05:04 PM
rsxer63's Avatar
Does anyone know if the oil pressure sensor and outside temp plug directly to the cluster or if they go to the CPU?
Old Aug 4, 2009 | 09:43 AM
rsxer63's Avatar
I found out it is for air psi for the tires... going to see if we can use it for boost psi.
whybshy
Dec 18, 2012 04:19 PM
whybshy
Dec 13, 2012 01:02 PM
l s2000 l
Aug 18, 2011 04:31 PM
07s2kap2
Nov 28, 2009 12:28 PM
ph09kng
Feb 17, 2009 10:16 PM
