s2000 ESP in different project car
Old Feb 13, 2006 | 04:42 AM
rcodea's Avatar
Default s2000 ESP in different project car
Hello all, I was hoping to get some info from the maters. I hope you guys can help me!
Ok, I am trying to use the EPS system in a project car of mine. I have it all mounted, ready for the wiring. Since I am not using the f20 motor or tranny, I need some help with deciding what to use for the EPS computer inputs. Based on the factory wiring diagram I have, the following are all inputs:
1)B+ constant
2)B+ IG1
3)speedometer signal from gauge assembly
4)tach signal from ECM
5)"EPS load detect" from ECM, speed signal maybe?
6)3 wires for torque sensor
From what I have read, the system only uses the torque signal and the speed signal to operate the EPS. With that said, why would they have 2 inputs for the speed, and a tach signal? Which of these am I going to have to simulate?
My question is that since I am not using the ECM, speed, and tach signals, is it possible to "fool" the system into working properly? Is there a way to wire it all up so that I can get the powersteering to work without those signals? If I really do need a speed signal, would a 12V with a rheostat to change the voltage simulate it for a specific speed, then just adjust it as I need?
Any other ideas to make this thing work would be greatly appreciated. There has to be a way to get this wiring worked out so that I can use it.
Thanks guys
Ryan
rcodea
Feb 9, 2006 02:00 PM
elude
Jan 25, 2006 01:57 PM
MB06
Mar 18, 2004 08:56 PM
s2k_extreme
Jan 20, 2004 02:06 PM
johninator
Nov 15, 2003 11:09 AM
