Satilite radio in my 02
Hey everyone, I want to get Sirus radio or Xm, Either one I don't care. But I really want to keep the stock radio in my car, I'm pretty sure I saw a Xm antenna on a 2004 s2000, Do you think I could get my hands on a 04 radio and get the antenna and be set?
btw I don't want handheld ones...
Thanks
Thanks
IF YOU ARE LOOKING FOR ONE THAT WILL INSTALL ON OUR FACTOR S2K RADIOS.....GO WITH THE XM COMMANDER, IT IS AN ADD ON UNIT THAT IS WIRED INTO YOU FM RADIO............. IT WORKS OUT REALLY WELL ... AND PLUS U CAN LEAVE THE XM ANTENNA INSIDE TEH CAR IF U DONT WANT TO PUT IT OUTSIDE
I have an 02 S2K and added XM to the stock radio with no problems. Here's what I have:
1 - PIE Aux adapter to plug into CD-Changer port for an auxilary input. Be sure to install a switch on the ground wire of the signal wires so you can switch between car-powered and battery-powered devices.
2 - Sony XM radio kit. Be sure to get the second generation version because it's a lot better. These can be found cheap on ebay. I mounted the antenna between the passenger roll hoop so it's pretty discreet yet has no reception problems.
3 - Scosche CD player mount. I mounted it using the existing screw on the passenger side net on the transmission tunnel.
If you need pics, let me know and I'll post them later. Good luck!
