Should I Bridge my amp?
Old Jun 24, 2010 | 04:34 PM
CreAziaN's Avatar
Default Should I Bridge my amp?
Running component speakers only with an amp
Polk Audio MM6501 Component Speakers:
* 2.7-ohm impedance
* power range: 25-125 watts RMS (250 watts peak power)
* frequency response: 40-25,000 Hz
* sensitivity: 94 dB
Alpine MRV-F340 Amp:
* 55 watts RMS x 4 at 4 ohms
* 65 watts RMS x 4 at 2 ohms
* 130 watts RMS x 2 in bridged mode
* Minimum Impedance Bridged: 4
should I bridge my amp? Channels 3 and 4 aren't being used nor do I have any plans for a sub in the future. Would the speakers appreciate the extra power or would the amp run too hot if bridged?
http://www.crutchfield.com/p_500MRVF340/Al...40&ssi=0&tp=115
http://signature.crutchfield.com/s_107MM65...ch=mm6501&ssi=0
Old Jun 24, 2010 | 08:46 PM
RsxFlyBy's Avatar
In one word......ABSOLUTELY. Your speakers will thank you for it
Old Jun 25, 2010 | 12:48 AM
CreAziaN's Avatar
will the amp run hotter or any higher risk of failures?
Old Jun 25, 2010 | 10:34 AM
RsxFlyBy's Avatar
After reviewing the specs of the amp and the speakers, I don't think that bridging will be a good idea. If you had 4 ohm speakers, or an amp that was capable of being bridged at 2.7 ohms then I would absolutely recommend it. In this case you amp would run too hot. Sorry about that.
Huntsmcgee
Jun 5, 2010 10:49 PM
s2krazy01
Jul 11, 2007 09:44 PM
yungjoc
Jun 18, 2007 08:44 AM
aggie
Feb 3, 2005 01:30 PM
kw2000
Jan 15, 2005 07:03 PM
